Well I pulled it off, I think. Replaced the outer U-joint on my front axle. My question is after pounding for almost 40 minutes to get the hub off, I have basically destroyed the tin shield. What does it shield and is really necessary? I know it's probably cheap, but the local parts guys don't have one, I really don't want to go to a wrecker and pound on another one only to wreck it too, and the Ford dealers parts department aren't open Sundays. I want to put it back together tomorrow Sunday).
They were missing from my spindles when I got my 95 Bronco, but I had them on my BII. I mangled them like you did taking the spindle off and in both cases they were eliminated. I think they are there to prevent the spindle from rusting permenantly to the truck. I cant really see any other possible function to them.
They are actually dust shields to keep all the crap from collecting on the rotors. In reality they manage to keep mud and debris right next to the rotor while off roading. I cut off everything except the inner piece (like a washer or shim), to keep the spacing right between the spindle and axle, on my 88 and had no problems with the bearings/u-joints or anything else on the drive train for over 20,000 km before the back of the tranny fell off.
My worry is that it's thickness is required (like a shim). I doubt it. I do very little off-roading, so I'm not too concerned about dust and/or mud. I'll leave it out and hope for the best.
you should replace it and when you aquire your new one, use a spindle puller soyou dont have to beat it up to get it off. Its a cheap tool that will save both the spindle and the shield for damage
Yeah, for future reference, go to Autozone next time and rent the slide hammer that has the three prong puller(used to pull the spindle bearing). Also get the extra 4wd spindle puller. It will thread onto the spindle and after oh......about 30sec. you will have the spindle off. Expect to shell out about $140 for the rental of everything, but is completely returned once you return the tool. Basically, they make you buy it and all you have to do is bring the tool back with your receipt for a refund.
As far as the dust shield. I removed mine just because I hated when rocks would get stuck between it and the rotor when going offroad(especially after playing in a little mud _. Mine have been off for a few years now.
