Installing a dodge V10 nv4500 in a 75 f-250 4x4. It has the 1.25" 10 spline input shaft. Anybody know if there's a clutch disc available that will work with a ford FE flywheel? Thanks.
Double check this to be sure but if you want to use a 12 inch disc a 92 Ford /460 is a 1.25 10spline 12 inch. If you want an 11 inch try a 93-94 7.3 Diesel F250/350, but double check this cause Im not sure.
