what do ya think?
Old Mar 17, 2006 | 08:33 PM
firstf250's Avatar
firstf250
what do ya think?
when i accelerate in my f250 with a 400 it feels like the power is choppy almost like it is missing. but when i push in the clutch the motor is smoth as can be.could it be the trans going bad?
Old Mar 17, 2006 | 08:55 PM
jade79's Avatar
jade79
I'd check the spark plugs, spark plug wires, distributor cap and rotor first. A lot of times a bad ignition system will cause problems which would lead you to believe the trans is causing the problem.
Old Mar 18, 2006 | 12:32 AM
3rdshiftzombie's Avatar
3rdshiftzombie
I would look at the fuel filter.When you push the clutch in the engine is no longer under a load so there for it does not require as much fuel however when you release the clutch it may be starving for gas.This has happened to me on my 78 F250 4x4 with the 400m.May as well do a complete tune up while your at it which should include a check of the vacume advance at the distributer.Good luck.
Old Mar 18, 2006 | 03:22 AM
Bdox's Avatar
Bdox
Any peculiar noises?
Old Mar 18, 2006 | 12:19 PM
firstf250's Avatar
firstf250
nope noise just stumbles when accelerating and when i push in the clutch and push on the gas it reves great. i will try the tune up first i just got it a few weeks ago and i dont know the maintenance plan.
