more DTC's. suuuper.
12: cannot control RPM during self-test high RPM check.
44: thermactor AIS sys system inoperative right side. (this should be a big DUH since the previous owner took the pump off)
13: cannot control RPM during self test Low RPM check
25: dyn response test knkock sensor not detected
great. now what? i HAD this thing running fine after i swapped out the wires and plugs. it was idling alot better as it always used to idle high as the sky. then i went to check for KOER codes and grabbed the couple in the engine compartment then the truck died. turns out one of the leads in the fuel pump relay corroded and broke off starving the fuel pump of power to run.
i have since replaced that terminal with a new one and it started right up. and the codes above is what i got this time. please note that it now idling where it used to originally, high as the moon.
