axle ID
Old Mar 17, 2006 | 04:42 PM
frankenford06's Avatar
frankenford06
Talking axle ID
Hi newbie here, I've been through the decoder chearts and door tag post but can't find mine listed can anyone assist? 1984 E-350 door tag axle code 31.I believe it's a Dana 60 would like to know ratio to see if it worth pulling out to rebuild .
Old Mar 18, 2006 | 11:55 AM
frankenford06
should I be posting this elsewhere in forums ? I'm still learning my way around here.
Old Mar 21, 2006 | 02:39 AM
Matts72's Avatar
Matts72
Welcome to FTE... unless its a Dual Rear wheel, it should be a Dana 60, if it is a DRW, its a Dana 135. There should be a tag attached to a bolt on one of the bolts on the carrier or cover, that will tell you the ratio and if its a limited slip or open differential.
I'll move this post to the correct forum for you...
Old Mar 21, 2006 | 04:17 AM
Dungeon_Master's Avatar
Dungeon_Master
Conventional:Non-limited slip
Axle code:
Code...........Man.........Size...GVW…..Gear Ratio
31.............Dana 61..............6250....3.07
Old Mar 21, 2006 | 03:04 PM
frankenford06
Thanks, you guys are the greatest
