Brake peadle
Old Jan 6, 2001 | 08:52 AM
StockMan's Avatar
StockMan
Brake peadle
Old Jan 9, 2001 | 06:48 PM
bigf150's Avatar
bigf150
Brake peadle
Whenever I push the brakes on my 79 f150 they either come back up very slowly or dont come back up at all, what could be a few reasons this would be doing this? Thank you for reading this subject.
Anthony DiPietro
79 F150 Ranger
Old Jan 9, 2001 | 07:05 PM
trouble's Avatar
trouble
Brake peadle
Have you checked your brake fluid .. If its full id try bleeding them .check your mastercylinder and booster also.
Old Jan 10, 2001 | 04:56 AM
karljay's Avatar
karljay
Brake peadle
If you're brakes work fine other than this, I'd check the return spring at the top of the pedal. It should connect back to a bar about 1' up from the pedal. If your brakes go down too far, or are soft, I'd check the mast cyl.
Old Jan 10, 2001 | 05:32 AM
StockMan's Avatar
StockMan
Brake peadle
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
I wasn't aware of any "external" return spring on the ppedal...certainly not on the older ones. A dry MC is right on the mark, but it also could be that the brake shoe return springs are not doing their part, or that one or more of the wheel cylinders is seized up. Sounds like you should start from scratch and check every aspect of the brake system. Your life and mine may depend on it. :-)
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Jan 10, 2001 | 06:31 PM
bigf150's Avatar
bigf150
Brake peadle
Im gonna pull the wheels off when it gets a lil warmer out thanks for the help.
Anthony DiPietro
79 F150 Ranger
Old Jan 11, 2001 | 05:10 AM
karljay's Avatar
karljay
Brake peadle
You're right, I was thinking of the clutch pedal.
