Question About Checking Timing
Old Mar 17, 2006 | 11:57 AM
Rags's Avatar
Rags
Hi
I Have a 94 Ranger 4.0 Just going over it & checking everything I pulled the spout connector while it was running & there was no change in RPM's -Nothing! it even drove the same. I get no check engine light & have no codes in memory.
On my 88 Ranger 2.9 When you pull the spout the RPM's Drop & it also needs pulled to set the timing.
I Know the 88 is distributor & the 94 is Coil Packs so would there be a difference in the way the computor controls the timing?
Old Mar 17, 2006 | 01:07 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
On the 94 4.0 (has no distributor), timing is fully controlled by the ECM. What you pulled is probably the jumper used to modify base timing.
