radious arm bracket.
Old Mar 17, 2006 | 10:22 AM
frankenbroncoII's Avatar
frankenbroncoII
Question radious arm bracket.
hello all ranger fans! i just came back from the salvage yard with a replacement radious arm bracket. (last one they had too.. they are on a crushing spree and just a hand full of 80s rangers left ) any who, obviously i can not resuse the rivots lol so bolts are going back in. im thinking grade 5 should be sufficiant. i was wondering how much torque i should put on them.
Old Mar 17, 2006 | 12:39 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Fastener preload, and thus applied torque, will depend on the fastener diameter.
Old Mar 17, 2006 | 12:59 PM
Rags's Avatar
Rags
Mine was worn out on my 94 and it was part of a cross member I was looking a salvagge yard for one, checked with ford they had it & it was $25.00 NEW!
I just used hardened bolts & Lock washers & tightend as tight as I could get
Old Mar 17, 2006 | 01:01 PM
wtroger's Avatar
wtroger
I would spring for at least grade 8 bolts and would use grade 12 if I could find them. And cowboybillie is right torque depends on size. grade 8 3/8 " is 45 ft lbs. grade 8 7/16' is 70 ft lbs. grade 8 1/2" 110 ft lbs grade 8 9/16" is 150 ft lbs. these are listing for standard thread bolts. Fine thread bolts have a dry torque value about 10% higher
Old Mar 17, 2006 | 01:05 PM
frankenbroncoII
sweet thanx for all the replies, most informative. now its off to slowes home improvement for some bolts
Old Mar 17, 2006 | 01:08 PM
wtroger's Avatar
wtroger
If you have a farm and ranch store handy they usually sell bolts by the lb instead of the piece and that makes them a lot cheaper.
Old Mar 18, 2006 | 07:43 AM
frankenbroncoII
the nearest wholesale farm supply is an hour drive from. and with fuel at a current price of 2.53..(uhh was 2.43 yesterday..) the price difference is minumal at best.
Old Mar 19, 2006 | 03:45 PM
frankenbroncoII
alright friends old bracket is off and "new" one is on. those rivots were tougher to get than i first thought but i got er done. though i would reconmend haveing a buddy help you, tis almost to much of a job for one man to do alone. any who thanks for all your help and information.
Old Mar 19, 2006 | 03:55 PM
natebaker's Avatar
natebaker
Call me crazy, but wth is a radius arm bracket??
Old Mar 19, 2006 | 06:07 PM
Tiggie's Avatar
Tiggie
It's where the radius arm attaches to the frame. The bracket is normally riveted to the frame. Part #3 in the below diagram is the radius arm, part #5 is the radius arm bracket.
Old Mar 19, 2006 | 06:10 PM
natebaker's Avatar
natebaker
I've got you now! Thanks for the enlightenment!
