Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
leaking water pump or hose
Old Apr 4, 2002 | 07:01 PM
Avanti's Avatar
Avanti
Often engine coolant leaks do not show up on the garage floor untill they are bad. If you suspect your water pump is leaking, it could be from the weep hole on the casting. To check for a leak their cram a piece of white paper towel up in each hole at night after you finish driving the truck. Check it in the morning to see if it is wet or the color has changed. If no change put the towel back in and drive it. Than check it again at the end of day. For a suspected hose leak at a connection wrap and tape a piece of paper towel around the connections after driving the truck for the day. Check the towels in the morning for wetness or color change.
Old Aug 7, 2002 | 02:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Kind of like the "white glove" treatment!
Good idea, Thanks!
Old Aug 7, 2002 | 02:43 PM
Torque1st's Avatar
Torque1st
Posting Legend
sammie0126
Nov 27, 2013 11:53 AM
Evan_P
Jun 30, 2013 10:01 PM
Big Sky
Sep 12, 2009 06:24 PM
b4hntn
1978 - 1996 Big Bronco
Jun 21, 2008 05:51 PM
DashTrash
2004 - 2008 F150
Jun 29, 2007 04:53 PM
