Code Po401
Old Mar 16, 2006 | 09:37 AM
bertExpy's Avatar
bertExpy
Cool Code Po401
Hi
I Have My Check Engine Light On And I Run The Code Reader And Gave Me Code P0401.
Do You Guys Know Where De Egr Valve Its Located?
Because I Need To Clean Or Replace It
Or Do You Know How To Fix This Code
Thanks
Great Forum
Old Mar 16, 2006 | 09:49 AM
wavinwayne's Avatar
wavinwayne
Chances are the EGR passages from the throttle body to the EGR valve are completely clogged with hard black carbon deposits.
The only real fix is to disassemble the throttle body & clean out the EGR passages. It's not a hard job, just takes a little time, patience, & 3 new gaskets. I did it yesterday on my '97 Expedition.
Check it out here:
'97 Expedition EGR passages cleaned
Old Mar 16, 2006 | 10:49 AM
triton54's Avatar
triton54
Man i picked up a haynes manual at advance auto for about $18. Tells you about everything you want to know and its pretty dummy proof. I would suggest spending the $18 instead of gettin reemed elsewhere.
Old Mar 16, 2006 | 09:03 PM
bertExpy's Avatar
bertExpy
Thanks Guys For The Quick Response
I Will Try It This Weekend
Thanks Again
