Sponsored by: Auxito
OEM grill
Old Mar 16, 2006 | 08:28 AM
mattlikeshockey's Avatar
mattlikeshockey
OEM grill
I am looking for a stock grill for my 98 f150. I have the xlt, but I think its the sport or the stk that has the honey comb grill that I was to use instead.
Ive tried ebay, but no luck. Anyone know where I can order it?
Old Mar 16, 2006 | 09:14 AM
Smaug's Avatar
Smaug
On 97-98, the surround w/ the bar style grill is one piece and you will have to order a new surround and the grill.
Old Mar 16, 2006 | 12:28 PM
mattlikeshockey
so even if I wanted to do a billet grill?
Which surrond isnt attached to the grill? the painted sport / stx grill?
Old Mar 16, 2006 | 05:30 PM
Smaug's Avatar
Smaug
If you want to do a billet, you can get a bolt over or you can cut the grill out. The STX grill is a snap in along w/ the Lariat.
Old Mar 17, 2006 | 02:38 PM
crazyscott's Avatar
crazyscott
I would Highly recomend getting the billet grill for the truck they just make it stand out that much more, but if you do buy one get the one where you cut rather than bolt over. they look much better
Old Mar 17, 2006 | 02:47 PM
mattlikeshockey
yeah, I have seen the bolt overs. You can always tell.
So I can just pull out my saws all and hack into the grill? or is there a better way to ditch the bars?
Old Mar 17, 2006 | 05:10 PM
Smaug's Avatar
Smaug
B4 I put the 99-up front end on, I cut the original surround and put a billet grill in. The opening in the bar style is slightly larger and I had to fill in the upper corners w/ plastic, epoxy, and bondo. Look close at the pic and you can see where the line goes toward the outside then cuts the other way. I've seen other pics where the bars were cut out and they didn't have to mod the surround like I did.
lightninquick
Nov 4, 2012 09:26 AM
thejean
Alberta Chapter
Jun 28, 2011 04:56 PM
f350sdv10
Feb 4, 2010 04:49 PM
J Hodges
Jan 4, 2008 03:01 PM
2FastLX
2004 - 2008 F150
Feb 19, 2004 03:22 PM
