o/t technology challenged!
Old Mar 15, 2006 | 11:54 PM
fordeverpower's Avatar
fordeverpower
I want to get picture's to my computer for my gallery. I have yet to get a camera, but i was wondering what equipment/cords are needed to get pictures on my hardrive. I have only used film camera's so i need all the help i can get.
Old Mar 16, 2006 | 02:08 AM
biz4two's Avatar
biz4two
Lightbulb
fordeverpower --
Here is a simple suggestion without getting a new digital camera or needing any cords plugged into your computer.
With your 35mm or disposable camera take pictures just like normal. Then take the film/disposable camera to Wally World, Walgreens, etc. On the envelope for developing the film...you should find an option to have your pictures also put on CD. Buy the CD option...and now you have pictures in a .jpeg format. Load the CD on your computer...and download to a directory. Now you have digital images for your gallery.
Hope that helps...
biz
________________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Mar 16, 2006 | 05:03 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
We use the Kodak easy share deal. The camera and software was like a tic over $100. Everything you need and it's pretty easy to use.
G.
Old Mar 16, 2006 | 08:15 AM
jor's Avatar
jor
Biz4Two's solution is excellent in that you don't even have to buy a camera. If you do decide to buy, however, there are lots of choices. I use a middle-of-the road Kodac which is pretty much point and shoot. It comes with a cradle that charges the camera and also automatically loads the photos into your PC. It uses a USB port/cable which all newer PCs have. I just saw an advertisement for a Kodac wireless so I guess you can get one now that just needs to be near the PC to transfer the photos. Good luck.
jor
Old Mar 17, 2006 | 12:04 AM
AnOldDog's Avatar
AnOldDog
Most digital cameras use a USB (Universal Serial Bus) connection to download the images from the camera to the computer. As far as I know, all personal computers dating back to about 1998 or so have USB available. It is now commonly used for printers, cameras, scanners, and just about every other kind of peripheral piece of equipment.
I have two digital cameras and am quite pleased with both of them. I have a nice Canon SLR that I can use fancy lenses, and I have a Fugi Finepix that does a great job of point and shoot photography. Don't spend a lot of money on a camera that you will be using for web pages. It doesn't take much of a camera to create great images that fit in a web browser. The more expensive cameras are worth it if you want to make framed photo quality prints to hang in your living room.
Go cheap, with a major brand name, and be happy.
Old Mar 17, 2006 | 08:35 AM
jor's Avatar
jor
This is great advice. Number of pixel is all about printing size. If your intents (as is mine) is simply to see your photos on a computer or publish them to a website, any 2 megapixel camera is just fine. No matter how high the camera resolution, a computer will only display its own resolution (800X600, 1,024X768 or whatever). Let us know how you go.
jor
Old Mar 17, 2006 | 02:20 PM
77fordguy's Avatar
77fordguy
jor
picture quality increases with the number of pixels. a 4MP camera will have a better picture than a 2MP camera. Get a camera with the most pixels you can for your money. I prefer Canon camera's. All of the new models are very easy to work and also easy to transfer pictures to your pc. good luck
Old Mar 17, 2006 | 07:08 PM
Hypoid's Avatar
Hypoid
This is all pretty good stuff. I have not made the leap to digital because I'm just too darn picky about image quality. We have a scanner/printer with card ports; so far I like it, have not really learned to use the editing software that came with. Are all the editing softwares about the same? Just how many Pixels are enough for a decent 8x10 or 11x14 print?
Old Mar 17, 2006 | 08:15 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
I install prints in the scanner then go to jpeg.
.....=o&o>.....
Old Mar 17, 2006 | 08:40 PM
jor's Avatar
jor
This is a common assumption and is at least partially true but not really accurate. You are always limited by your output device. Anyhow, there's a great website for learning about pixels, resolution, display and printing for anyone that's interested. It's at:
http://www.scantips.com/
Old Mar 17, 2006 | 11:51 PM
fordeverpower
Thanks for the replies!
Can I use my usb from my printer to hardrive or will I need another one?
Old Mar 18, 2006 | 08:40 AM
jor's Avatar
jor
I'm not sure I understand your question but if you are out of USB ports you can buy a little (4 banger) USB hub and expand the number of available ports. I think you can even chain USB devices in some cases. Anyhow, you can pick up a hub at CompUSA, Target or just about any store with an electronics section. Good luck.
jor
Old Mar 18, 2006 | 08:56 AM
jd_sylvia's Avatar
jd_sylvia
I have bought and owned several digital cameras and so far my favorite is the Kodak easy share. It is like someone said point and click. I have also learned that if you start storing 5 mega pixel shots you will need a second hard drive. If you are going to be using for post and emailing friends switch your camera to the lowest setting 1.8 on the easyshare it takes up alot less hard drive.
I bought a Cannon for one of my sons a HP for another one of my sons and a Kodak for my oldest son and they all have good luck with all of them.
When you get ready do your research and buy something easy to use.
I like my Kodak because it came with the usb craddle and I can pull the memorey card and slip it into a adapter and into my laptop any where I go. I also have a couple of memorey cards for backup.
The easyshare also does video with sound that works very good.
my .02
jd
Old Mar 23, 2006 | 01:57 PM
fordeverpower
follow up?
I just bought a kodax easy share c310 camera. I have been playing around but have run into a problem. I took some pictures and transfered them via the software but I want to pictures in "my pictures" in my documents. I have windows XP, and i want the pictures in my documents.
When I tried send them there it didn't work. Any thoughts, and whats the best overall flash setting on the camera?
edit, a big wtf, the kodax crap is controlling all pictures on my computer even when the software is shut down. This is bs!
Old Mar 23, 2006 | 08:19 PM
jd_sylvia's Avatar
jd_sylvia
I love the Kodak cameras but I will never install thier software ever again. It is like a virus takes over and wnats to be in charge.
You may have to use your explorer to move the pictures. If memorey serves me there should be a Kodak directory and it has sub directories that are the dates you downloaded them.
Good luck with that..
jd
