Bronco II Ford Bronco II
'88 engine options and problems
Old Mar 15, 2006 | 07:15 PM
sevenL4's Avatar
sevenL4
I've got a chance to buy a pretty clean '88 Bronco II and to get it cheap. I've only seen photos so far and I'd like to be prepared when I actually see it. The owner says "it runs well except for a leaking head gasket". I tried getting more info but she doesn't know if it's a 4 or 6 cylinder engine so I stopped there.
My questions to the board are;
1. What are the engine options in 1988?
2. Are there known problems with any particular engine?
3. It is a 4x4. What kind of life can I expect for the auto transmission?
4. Any quirks or eccentricities that you know of?
Thanks in advance for any information you guys can give me.
sevenL4
Old Mar 15, 2006 | 07:25 PM
Ken00's Avatar
Ken00
The only engine for 88 was the 2.9L V-6.
They are known for cracking heads when overheated, they are NOT known for head gasket problems. If you don't overheat them they are good engines.
Most are 4wd.
Old Mar 18, 2006 | 10:08 PM
Monty06's Avatar
Monty06
auto tranny would be a4ld if you treat them good i.e. pretend not to be racing .
the tranny will give you good work.
all 86-90 b2 came v6 2.9L either auto or stick 4x4 mostly like ken states only major problem is overheating. most bronco2's have a lifter tick problem .
Old Mar 19, 2006 | 09:04 AM
rebocardo's Avatar
rebocardo
If poorly treated (not serviced) you can expect about 80-100k tops. I believe in doing the tranny fluids frequently, changed at every 20-30k miles tops. Doing it yourself I think every year is great. For less then $30 for filter and fluid it is worth it.
My BII was beat on, snow plowing, putting down the rear seats and loading the back to the ceiling with birch firewood and driving it out of a swamp area, off roading down ATV trails, pedal to the metal, etc.. The auto lasted to 148,000.
That leaking head gasket to me says cracked heads. I would assume a new rebuilt engine is needed if they have been driving it because they have probably damaged the engine by now.
Old Mar 19, 2006 | 09:13 PM
Desert Dog's Avatar
Desert Dog
I think the best set up is manual hubs and 5 speed manual but thats my preferance.
