hello all im getting toward the end of my e40d to 4 speed conversion it a 93 f350 7.3 e4od goin to 4 speed the pedals are in the cluthch flywheel bellhousing etc are on all i need to do is insatll the trans and tranfer shifters etc my ? is how do i wire up my clutch safety switck and my reverse lights i know the mlps controlled that but it has quite a few wires on it my ? is wich one do i need for rev lights and neutral safety thanks
chris
The neutral safety switch wires need to go to the clutch pedal switch. Clutch must be depressed for the engine to crank.
Looks like that wire should be gray with yellow stripe according to my book for power into the switch.
Power out of the switch to the starter relay is red with lite blue stripe.
Reverse lights look like purple with orange stripe in the book for power into the switch.
Looks like black with pink stripe for power out of the switch.
