Tachometer sending unit location
Old Mar 15, 2006 | 02:46 AM
zodiak12's Avatar
zodiak12
Hi Fellas
Where is the Techometer Sending unit located in a 1990 7.3L diesel Motor.
Old Mar 15, 2006 | 06:35 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 15, 2006 | 07:31 AM
deanj's Avatar
deanj
Look at the front of the engine, to the side of the oil filler their is a large 1 inch nut that has 2 wires comming out the top - thats it.
Old Mar 15, 2006 | 07:32 AM
PLC7.3's Avatar
PLC7.3
On top of the oil filler/timing gear cover its a 1" nut with wires........
The dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel, and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too. You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
ARK Ranger
1997 - 2003 F150
Feb 11, 2012 01:39 PM
BigBlue92
Apr 7, 2011 05:04 PM
bubbasz1
Nov 18, 2008 10:47 AM
7pointstar
May 10, 2007 01:02 PM
teederj2002
Oct 21, 2003 12:06 PM
