Sponsored by: Real Truck
Trailer lights dead....how many fuses??
Old Mar 14, 2006 | 09:59 PM
ag-ford-4x4's Avatar
ag-ford-4x4
I was trying to put some new lights on my boat trailer, and i wanted to test them with the truck, so i used the wifes. Lights came on, when you pushed the brake, all trailer lights went off until you got off the brake. Tried some stuff, then no lights on trailer at all. So i tried my truck...same thing. So, i checked my fuse just now, and a 20 amp "Trailer park lamp" fuse is blown. Is thois the only one responsible for the trailer lights?? I went ahead and pulled all the wire out of the trailer, a whole new harness is 9 bucks, and i figure thats what the problem is, its old, not likely both our trucks have a short.
Old Mar 14, 2006 | 10:18 PM
HarryD001's Avatar
HarryD001
my 99 F250 had a fuse under the hood on the drivers side wheel well. I had the same prob blew a fuse and went nuts looking for it
Old Mar 15, 2006 | 01:54 AM
WolfCreek's Avatar
WolfCreek
My '06 F350 with (w/ Tow Command) also has a fuse box driver's side under the hood. Some of the trailer fuses are in there. When the truck was just a couple of weeks old some trailer lights went out. I couldn't find a blown fuse (I only looked in the inside fuse box), so went storming back to the dealer, ranting about "brand new truck designed for towing and trailer lights don't work"! I felt mighty foolish when the mechanic popped the hood and showed me the blown fuse.
-robert
Old Mar 15, 2006 | 10:07 AM
ag-ford-4x4
what makes it blow fuses?? Poor wiring on trailer or in truck?
Old Mar 15, 2006 | 10:45 AM
03EDGE's Avatar
03EDGE
Your trailer wiring is probably shorted out somewhere. The fact that you blew fuses in both trucks leads to that.
Old Mar 15, 2006 | 10:50 AM
ag-ford-4x4
Yeah, i bought a new wiring harness for the boat, 9 bucks, hardly worth it to take a chance. Im not used to blowing a trailer light fuse. ON my 96 dodge, if you shorted out, fuses for instrument cluster, or horn, or tail lights blew instead. Trailer stuff was not on a separate circuit.
Old Mar 15, 2006 | 08:29 PM
JimBrazil's Avatar
JimBrazil
Check #38
This fuse is for the trailer running lights.
JimB
mitsudave
1997 - 2003 F150
13
Oct 24, 2012 06:27 PM
Glockem45
All Things Towing
41
Nov 12, 2010 05:56 PM
bozcoyote
Apr 1, 2010 10:55 PM
72soa
Oct 23, 2007 04:23 PM
jjbigwheel
All Things Towing
Sep 28, 2006 08:16 PM
