Edelbrock 1406
Old Jan 19, 2001 | 08:31 PM
rlehman's Avatar
rlehman
Edelbrock 1406
Tossed the leaky Holly and installed an Edelbrock 1406.
This is to others running this carb. Have you changed the Rods/Jets according to the book that came with the carb? And if so any success using the book as a guide? I am planning on leaning out some, just wondering.
74/F250/390
Bob L
Old Jan 19, 2001 | 10:34 PM
jbhf250's Avatar
jbhf250
Edelbrock 1406
>an Edelbrock 1406. <<
>that came with the carb? <<
YES
>using the book as a
I have changed just about everything, and did follow the book!
On My 390 going larger in the jet size was dramatic. Change the rods for slight improvements. I now use the `stock` setup for the street.
But at the strip i go up `several` sizes on the rods.
I don`t have the book here now, or I could tell you.
You can go `larger` on the jets and not see any great change in color to the plugs in the short run.
If you get any `hesitation` when you slightly open the throttle, try going to `smaller rods like .072x.037 (Guessing here)..I think stock is .075x.047 (guessing here)
>74/F250/390
>Bob L
As you can tell the 1406 worked for me.
I hope you have good luck with yours
__JOHN__Õ¿ö
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
Old Jan 21, 2001 | 01:19 AM
390GT's Avatar
390GT
Edelbrock 1406
Old Jan 21, 2001 | 07:57 AM
fe4ever's Avatar
fe4ever
Edelbrock 1406
By all means, play with it! BUT, I'm sure you'll find that the stock jetting is just about as lean as you can get without pre-ignition.
The beauty of the Carter/Edelbrock carb, is how easy it is to adjust!
Old Jan 21, 2001 | 09:17 AM
rlehman's Avatar
rlehman
Edelbrock 1406
Found a shop that carries the jets/rods. Leaned out one step from stock, timing set at sticker 16 btdc, installed new set of 45s gapped to 45, have the pertronix ignitor/coil and wire upgrade. Ran just fine, no lag or ping under load, will check plugs after awhile.
This being a stock 74 junior smog motor must be the reason I can lean out so far with that much advance?
Bob L
Old Jan 22, 2001 | 11:16 AM
dzjammer's Avatar
dzjammer
Edelbrock 1406
I leaned my idle down a step, but ended up leaving the cruise mixture about stock. I believe all I changed was the rods. I had mine so lean when I was experimenting, it wouldn't even pull itself up a hill. The Edelbrock is so much nicer than a Holley for everyday driving.
Dave,
79 F-150 4x4, 390 w/C6, Edelbrock carb, 33X12.50 never will be finished.
