Towing with 308's
Old Mar 14, 2006 | 08:02 PM
Mendocino101's Avatar
Mendocino101
Towing with 308's
I just bought a 96 F150 with the 300ci engine and 308 rear end. it is a auto and in the Ford trailer towing guide it claims 4900lbs of towing capacity ....I was skeptical but I am only going to be pulling between 1800 and 2300 lbs....Should I be OK....it is a Eddie Bauer edition with 74,000 miles on it and is very clean.....knew the owner and paid $4000.00....sound fair ?
Old Mar 14, 2006 | 08:44 PM
Mendocino101
lol.....I was hoping someone might have some input...anyone...anyone...
Old Mar 14, 2006 | 09:03 PM
benwantland's Avatar
benwantland
I would think you should be fine. I had that ratio in my 77 with a 300 carbed and a three speed manual, and was able to get my boat, which ways a few hundred pounds more than you are looking at, out of the water all the time... although it probably wasn't the best for the clutch. With an auto, you will be fine.
Old Mar 14, 2006 | 10:11 PM
Geneoh's Avatar
Geneoh
You'll be fine, 2000lb dose not even count
Gene
Old Mar 15, 2006 | 11:13 AM
chris_567's Avatar
chris_567
Make sure you're not using the OD
Old Mar 15, 2006 | 08:03 PM
77bigblock's Avatar
77bigblock
You will be just fine. I pulled probably twice that with my 78 F100 with a 300 and thre on the tree. Maybe that's why the rear end gears decinegrated?
Old Mar 15, 2006 | 08:25 PM
Popa Tim's Avatar
Popa Tim
the 300 is the towing monster! My buddy has tractors with the Ford 300 in them and pulls stumps...LOL
Old Mar 22, 2006 | 10:39 PM
fordtkguy's Avatar
fordtkguy
Have a 96 4.9 with 5spd manual. I pull a 3500# camper just fine. I've pulled as much as 8800# several times with no worries. I have beefed up the springs though to accomodate the increased load.
