overdrive woes
Old Mar 14, 2006 | 07:52 PM
jimbo beam's Avatar
jimbo beam
overdrive woes
hey, i have a 96 f150 with the e4od tranny. some times my overdrive works sometimes it dosnt, with overdrive on if i push the OD off button on the shifter nothing happens no OD OFF light and the overdrive stays on.
besides the overdrive thing the tranny seems ok, shifts through all other gears fine, shifts into overdrive fine when its wants to. im thinking this is some kind of computer problem.
during a recent mostly highway trip it didnt shift into overdrive when i was on the interstate, i drove maybe 20 miles before it sliped in.
like i said before i have no control over the overdrive, the button on the shifter has quit working.
if anyone can give any advice that would be great.
Old Mar 14, 2006 | 09:47 PM
Fully_Loaded's Avatar
Fully_Loaded
Does the overdrive light flash? If so it is flashing a fault code, count the flashes and that will be a good place to start.
Old Mar 14, 2006 | 10:18 PM
jimbo beam's Avatar
jimbo beam
when would this light flash? would there be flashing when i start the truck or at any time?
Old Mar 15, 2006 | 01:44 PM
neversosure's Avatar
neversosure
Should flash when you are driving it.
Old Mar 15, 2006 | 08:47 PM
Fully_Loaded
Or when you first crank it up.
Old Mar 15, 2006 | 08:49 PM
neversosure
Hey Full..... are talking about when you first start it or when you turn the key to run?
neversosure
HEY that was my 100th post! GO ME!
Old Mar 15, 2006 | 08:59 PM
Fully_Loaded
When you crank it. It usually takes a sec and if there is any codes it should flash them twice I believe. They will be 3 digit codes. Flash. Flash. short pause, Flash, Flash, Flash Short pause Flash, Flash, Flash. That would be code 233. The pause is very short. Hope this helps ask any more questions if you got em.
Old Mar 15, 2006 | 09:30 PM
neversosure
Are they the same codes stored in the eec as well for the trans?
