2002 Rear Door Lock Actuator
I have a 02 that the rear passenger door does not always unlock. I can hear the actuator doing something when I push the remote button but I cannot open the door from either the outside or by pulling the handle on the inside. If I manually push the button below the handle on the inside the door unlocks.
I pulled the door liner off and was trying to see what might be the cause.
What might be the things I should look for or consider replacing?
Thanks, Tom
