Having a few problems not bad ones just little ones. Have a 04 screw 5.4
shift in the floor it is making a noise around the shifter only when its in drive
with your foot on the brake? Also there is a rubbing noise in the steering
wheel some place. Last when you do an re-flash on these trucks will it reset
the computer mpg or will it stay the same as it was when you you took it in?
JUMP IN IF YOU KNOW WHAT ANY OF THIS COULD
Thanks xtrm1stang ford said they re-flashed mine but my mpg showed 15mpg
before it went in and 15mpg after it came out of the shop I was just thinking
if they re flashed it would have it went back to zero and started over
