i am trying a f350 with a 7.3 power stroke, is goes dead while you are driving it it is a 5 speed with overdrive, the hotter the truck gets it seams to die more, you can let it cool a little and it will start again.
thanks
Connie
The issue you're describing could possibly be a bad CMP aka CPS (camshaft positioning sensor). A quick search on CPS in this part of the forums will reveal a TON of info.
It's a $90 or so part that takes 10-20 minutes to change out with a 10mm socket and ratchet and a flat blad screw driver to pry the old one out.
I'm sure others will chime in with their thoughts, as well.
thanks
Connie
Welcome to FTE connie lawley!
Sounds like your CPS is giving u trouble.I would start there. I believe there is a connection with heat induced CPS failure according to other peoples reports.
Nut
If it's on a dealer's lot make them replace the cps before you even think about buying it. Then test drive it fairly hard to make sure that was what was wrong.
Joe
