460 flywheel
Old Mar 13, 2006 | 04:21 PM
theguy_88's Avatar
theguy_88
Question 460 flywheel
i am puting a 76 460 in to a 77 4x4 with a 400 with a 4sped trans and i would like to know what flywheels will work on this setup? also what has to be done to make one fit?
Old Mar 13, 2006 | 08:45 PM
greenhighboy's Avatar
greenhighboy
Get one for a 360/390. It will bolt right on and will be the right balance. If possible get one for a diaphram style pressure plate. Clearance gets tight in a 400 bellhousing,and a 11.5" long style won't fit and a 10.5" isn't big enough unless you use a real stronge pressure plate and metalic disc.
Old Mar 13, 2006 | 11:53 PM
wvmudder's Avatar
wvmudder
Can anyone put up a part number from advanced, auto zone, or napa? I am just wondering if anyone has the number they have used for the swap so I can get one with the correct pressure plate bolt pattern and tooth count. Thanks, Dave
Old Mar 14, 2006 | 12:28 PM
fordtruggy's Avatar
fordtruggy
Youll need a 460 bell housing also.
Old Mar 14, 2006 | 06:33 PM
Green Streak's Avatar
Green Streak
Pressure plate
What is a diaphram style pressure plate (sorry, I have never heard the term)
Old Mar 14, 2006 | 10:17 PM
greenhighboy
No, you don't need a 460 bellhousing.
A diaphram pressure plate are the ones with multiple springs for fingers like are commonly used on Chevy's. They are thinner and work better with a 400 bellhousing.
