Having read the posts responding to jspeggs alternator charging problem, it becomes clear that connecting my new electric choke to the alternator stator terminal is an option.
When I first got the choke, it had no wiring diagram. So I emailed Holley asking about the stator terminal connection and they emailed back saying: "You WILL connect the choke to a switched ignition source", like it was some kind of law or something.
Why would they say that if the stator connection is a viable option?
That's a interesting question because I had the same thing going on with the ederbrock carb. They said to use an ignition source for the choke.
Anyway, being a little hard-headed, I used the Alt. for the choke.
The choke operates just fine. Do not know what the difference would have made, but so far so good.
Besides I have other vehicles with factory elec. choke carbs. that are connected via the Alt.
So I don't know 'WHAT GIVES'.
I think the reason is protection of the choke unit and alternator. Unless you fuse the lead, you can have problems if it shorts out, as well as having arcing at a fuel source unchecked until it burns off/open. Just something to consider.
The choke needs to be connected to a circuit that is hot when engine is running, not with switch on only otherwise the choke will heat with engine off key on and will be open during cold start up.
