Bronco II Ford Bronco II
starting problem
Old Mar 13, 2006 | 12:30 PM
jjtopp1952's Avatar
jjtopp1952
Talking starting problem
hello all...got a ???? maybe someone can help me out here...i got in my 86 bII and went about 3 miles to the store...when i came out 10 min later the engine would crank but not start...acted as if it wasn't getting any fuel...waited about 10 min and turned the key and it finally started but was barely firing and i had to wait about a min befor it picked up any rpm...after this it seemed to run ok for the rest of the day...2.9L w/auto trans any help would be appreciated
Old Mar 13, 2006 | 01:21 PM
broncobillyII86's Avatar
broncobillyII86
There is a lil sound you can here just as you turn the key to here the pump in the tank if ya here that then it should be fine ......I had that same thought that it might be the pump but it was the coil and the wire to coil .....TR
Old Mar 13, 2006 | 07:37 PM
Ken00's Avatar
Ken00
I would start by checking the fuel pressure, if the fuel filter hasn't been changed in a while that would be a good idea.
Old Mar 15, 2006 | 03:55 PM
jjtopp1952's Avatar
jjtopp1952
ok..kinda busy but i will check that fpr...as soon as possible and let you know...can you tell me what the pressure should read...thanxz for the help both of ya
Old Mar 15, 2006 | 07:20 PM
Ken00's Avatar
Ken00
I like to see 35 - 45 psi.
