Door inserts
I'm rebuilding my 66 Custom Cab SWB and inquiring if anyone knows where to locate the interior door trim for this vehicle?
Specifically looking for the padding (which can most likely be fabricated) under the handles and chromed trim that goes around it as well as the plastic/chrome colored trim that goes around the box with a zipper that mounts on the bottom of the drivers door.
If I can't get there from here I'm going to look at a pre-fabricated door panel that covers the whole, below the window to the bottom unit.
Any suggestions or thoughts would be greatly appreciated.
Thanks
nighthawk
For the trim on the stock panels the only way to get it is to seach the yards or E Bay. the inner plastic panel is reproduced in black white and red.
Entire cover panels are produced by Rod Doors along with new arm rests.
Garbz
