Headlight Power?
Old Mar 13, 2006 | 09:45 AM
toyotajeep's Avatar
toyotajeep
Headlight Power?
Hello,
I have no voltage to my headlights. Is there a relay or something? It does not appear that there is a fuse in the box for the lights.
My truck is a 1989 f 150.
I do have running lights etc. just no voltage to the headlight sockets.
Thank You, ROB
Old Mar 13, 2006 | 10:11 AM
quicklook2's Avatar
quicklook2
the switch itself is a circuit breaker.
does it click?
Old Mar 13, 2006 | 10:15 AM
toyotajeep's Avatar
toyotajeep
no clicking or anything. There are is no power to the bulbs.
Old Mar 13, 2006 | 02:21 PM
Leader's Avatar
Leader
Did you check both Hi & Low beams ?
If only one is out, it might be the multi function switch.
Old Mar 13, 2006 | 02:54 PM
toyotajeep's Avatar
toyotajeep
No power on either circuit.
Hmmmmm.....
Old Mar 13, 2006 | 04:19 PM
F150xlt's Avatar
F150xlt
I'm looking at a wiring diagram for a 88 so hopefully the wire color codes are the same on a 89.
A fusible link from the battery feeds 12 volts direct to the Headlight switch via a Black/Orange wire. Since the Marker lights work, the fusible link is ok.
When you place the Headlight switch in the Head position (pulled all the way out) 12 volts goes thru the switch and out of the Switch via a Red/Yellow wire which goes to the Dimmer switch.
I believe your dimmer switch is mounted on the driver side floor. (Press with your left foot). The 12 volts goes thru the dimmer switch to light the Instrument cluster High beam indicator and High beam filament when the dimmer switch is in the High position.
If the dimmer switch is in the Low position, only the Low beam filaments will light.
So what you need to do is remove the Dimmer switch and use a volt meter to measure the voltage at the Red/Yellow wire at the Dimmer switch.
With the Headlight Switch on, you should measure 12 volts on the Red/Yellow wire.
If no 12 volts, the Headlight Switch is probably bad.
If you do measure 12 volts, with the Dimmer switch in the Low beam position, you should measure 12 volts on the Red/Black wire which goes to the Low beam filaments.
In the High beam position you should measure 12 volts on the Light Green wire which goes to the High beam filaments and Instrument Cluster High Beam indicator.
Old Mar 13, 2006 | 04:45 PM
toyotajeep's Avatar
toyotajeep
Wow! Like always this is a great source for information. I put my common sense hat on again and remembered the problems that I have had in the past.
I pulled up the floormat and removed the switch.
You guess it, hot in the middle.
I replaced it with a spare.........good to go.
I appreciate all of your help and guidance, ROB
