1978 - 1996 Big Bronco
Answer For Reprogramming Keyless Entry Transmitter
Old Mar 12, 2006 | 08:51 PM
Fishallot's Avatar
Fishallot
I saw a question not too long ago about someone wanting to know if they could reprogram the transmitter themselves or if they had to take it to the dealer. I was playing around with my CD-ROM service manual tonight and found the answer to this question. I can't find who it was that asked the question so I hope whomever it was see's this.
Remote Entry Receiver Module
The remote entry receiver module is located in the LH side of the lower instrument panel (04320) to the right of the steering column, just above the driver's right foot area.
Note:
The remote entry receiver module erases all previous transmitters from memory when the transmitters are programmed or reprogrammed. The remote entry receiver module can store up to four transmitters in memory.
To program (or reprogram) transmitter(s) into the remote entry receiver module, perform the following steps:
1. Turn key to the ON or ON/ACCESSORY position and momentarily short the two terminals of the program connector (C4) (a two-pin connector taped to the wire assembly connected to the remote entry receiver module, approximately 6 inches from the remote entry receiver module). All doors should lock then unlock. Remove shorting pin.
2. Press any button on transmitter. All doors should lock then unlock to verify that the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter).
3. Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
4. Key off. All doors should lock then unlock.
5. Check operation.
Old Mar 12, 2006 | 10:38 PM
69ford99's Avatar
69ford99
Thanks alot! I'll see if it works.
