Radiator Question
Old Mar 12, 2006 | 06:41 PM
tonpartain's Avatar
tonpartain
Radiator Question
Any recommendations on whether to use a radiator with a built-in transmission cooler or use a separate radiator and transmission cooler?
Old Mar 12, 2006 | 06:59 PM
scamardo's Avatar
scamardo
Really depends on a few factors. What build is your motor (stock, warm, race ready). I run a warm 390/C6 combo with no separate tranny cooler and works fine. I run my lines through the radiator.
Old Mar 12, 2006 | 07:03 PM
tonpartain's Avatar
tonpartain
My is build is:
360 block with 390 crank/rods
kb150 pistons
crane cam
ss valves
adjustable rocker arms/pushrods
headers
performer 390 manifold
mallory distributor
Old Mar 12, 2006 | 11:15 PM
biz4two's Avatar
biz4two
All depends really.
What trans do you have? C6?
What are you using your truck for? Towing? General usage? etc.
What is the climate like where you live? Hot? Mild summers?
I noticed your build of the FE. So...if you tow a lot and run in HOT summers, I would use an external trans cooler with an added electric fan.
However, if you use your truck to do general things...then you should be fine using the built-in trans cooler.
Good luck...
biz
TonyG
Oil & Lubrication
Apr 21, 2013 11:06 AM
jccapri
13
Dec 30, 2012 05:52 AM
johaner78
15
Jul 31, 2012 06:37 PM
390unibody
Sep 18, 2010 12:47 AM
65F100project
Oct 3, 2006 05:33 PM
