what is it
Old Mar 12, 2006 | 09:25 AM
ttriley's Avatar
ttriley
Question what is it
I have a 83 ford van axle tag wev aj 2j14 top row bottom row 300 9s7o48 I need to know what it is.I want a higher gear to drop rpm.
I found a 66 t bird with tag top wcd -h bottom 300 6cd 403.will this fit or work. thank you
Old Mar 12, 2006 | 12:24 PM
subford's Avatar
subford
WEV-AJ = Ford Tr. '79-81 E150
Ford Tr. '80-81 E100
Ratio = 3.00:1
Dia of R.G = 9.00
NL or L = NL
Axle Shaft Splines = 28
WCD-H = Thunderbird '66
Ratio = 3.00:1
Teeth R.G. = 39
Teeth P. = 13
Dia. of R.G = 9.0
NL or L = NL
They are the same, no change.
Old Mar 12, 2006 | 12:55 PM
ttriley's Avatar
ttriley
thanks subford do you know what i need to drop rpm. thanks
Old Mar 12, 2006 | 02:42 PM
subford's Avatar
subford
The next step down would be a 2.75:1.
Old Mar 12, 2006 | 04:12 PM
ttriley's Avatar
ttriley
subford what ring&pinon will i need to get 2.75:1 and were can I get third member with setup thanks for the help.
Old Mar 12, 2006 | 05:17 PM
subford's Avatar
subford
You have a 9" removable carrier so you can use any 9" carrier that has 28 splines. The carrier is real easy to change with no setup.
A 2.75:1 has 44 Teeth on the Ring Gear and 16 Teeth on the Pinion.
They are found in something like a '71 Ford SW with a 400.
Old Mar 12, 2006 | 07:46 PM
ttriley's Avatar
ttriley
ok I will start looking I heard you could change carrier by pulling axles. would atag show 273 on old axle like the 300 on mine.
I appreciate the help
Old Mar 13, 2006 | 09:53 AM
subford's Avatar
subford
I think you ment 275 and not 273, if so yes it would have 275 on it.
