newer body
Old Mar 12, 2006 | 07:31 AM
bootsman's Avatar
bootsman
newer body
can you put a 2000 f250 body on a 1975 f250 frame or has anybody ever tried this i think it would pretty cool THANKS
Old Mar 12, 2006 | 10:09 PM
The13thPlumber's Avatar
The13thPlumber
You can do anything. Just takes cubic money. I have been thinking about doing this but going the other way. Mid 70s body on a SD v10 frame and running gear. The problem as I see it is the difference in wheel base as the SD is several inches longer which in my case would mean shortening the frame. Also there would be major radiator support rework but I suppose bed and cab mounts would just need new holes drilled. Like I say , I am JUST THINKING about this. Maybe in 6 months after I retire and get a garage.................
Anyway, good luck if you try and if you do please POST PICTURES.
Old Mar 13, 2006 | 02:41 PM
User 71024's Avatar
User 71024
I put a 87 cab on a 79 F-250, everything lined up pretty good, I did have to make brackets for the body mounts but it was pretty basic.
