Frame Mounts
Old Jan 31, 2001 | 06:03 PM
canuck's Avatar
canuck
Frame Mounts
Is it true that that 351M and 400M used the same frame mounts as a 302-351W?
Thanks!
Old Jan 31, 2001 | 08:43 PM
Ford79's Avatar
Ford79
Frame Mounts
Old Jan 31, 2001 | 09:11 PM
beartracks's Avatar
beartracks
Frame Mounts
No.
1977 Ford F-100
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jan 31, 2001 | 11:30 PM
78ford's Avatar
78ford
Frame Mounts
Yes they will work! I just put a 302 in my truck I went to junk yard and found 351m Frame Mounts i had my doubts but I came home bolted them in and they work just fine! 302 Moter mounts fit in frame mount holes just fine! Tell you the truth I just done this about 4 hours ago!
Old Feb 1, 2001 | 07:49 AM
donberry's Avatar
donberry
Frame Mounts
I have a 1979 f150. Had a stock 302 in it. I put in a 400, same motor mounts etc, no problem whatsoever. dropped right in. I did run into problems trying to install headers though due to the steering gearbox being in the way.
Old Feb 1, 2001 | 08:14 AM
Trail_Rider's Avatar
Trail_Rider
Frame Mounts
...and I had problems (spell that REMOVE) with the kickdown linkage and firewall clearance problems when I put a Big Block (351M) into my '72 on Small Block (302) towers. Due to clearance problems the tranny will never come out of that truck without pulling the engine.
Trail Rider
Old Feb 1, 2001 | 10:42 AM
beartracks's Avatar
beartracks
Frame Mounts
I thought you meant the motor mounts which I believe are unique.
1977 Ford F-100
280,000 miles
