rusted leaf spring mounts
Old Mar 11, 2006 | 08:50 PM
fordtruck88's Avatar
fordtruck88
I have a 1994 f150 4X2 and today, while bolting tow hooks on, i noticed that one of the rear spring mounts that bolts to the frame is very rusted and has a large crack and hole in it. The other one is pretty bad too. How do you replace this? it is rivited on so im guessing i have to grind the rivits off to get the mount off? Also, if anyone replaced theirs, where did you buy it and about how much did it cost. And did it come with the piece that goes from the end of the spring to the bracket, or just the bracket?
thanks for the replies
Old Mar 11, 2006 | 09:23 PM
quicklook2's Avatar
quicklook2
do a search on rear shackle replacement and rear spring hanger for may posts on this.
just go to ford, the shackles are around 30 and the hanger around 70.
go to the national parts depot and download catalog, they have them also if you wantto compare price.
a very dirty job, but not real hard.
Old Mar 11, 2006 | 09:34 PM
Kansas-Mike's Avatar
Kansas-Mike
Where did you mount the tow hooks? And what do they look like?
Old Mar 11, 2006 | 09:56 PM
fordtruck88
I mounted the hooks on the bottom of my bumper bracket. Its a HD aftermarket bumper and the bracket actually fits over the frame instead of in it. Im not planning on using these very often, thats why i didn't put them on the truck frame. Also, the frame was so high up that if i put a chain to a hook on the frame it might come down and tear the bumper up I think they look good, you can see them from behind the truck. they are in a position so that they can be used eaisly. but im not gonna be able to use them until i get a new spring bracket.
