Just Curious
Old Mar 11, 2006 | 07:11 PM
Finally's Avatar
Finally
Just Curious
I had the following codes pop up tonite after I did a hard take off. The Predator tuner told me these were normal for a tuned engine. Just wanted to get anyone's opinion.
P0602
0605
1211
1690
0470
early '99, Kwik filter, shimmed fpr, 3.5" straight exhaust, 60 horse Predator tune
Old Mar 11, 2006 | 07:17 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
p0602- not on any code list i have
p0605- P0605 Internal Control Module ROM Error ???
p1211- ICP Not Controllable - Pressure Abow/Below Desired
p1690- Wastegate Control Valve Malfunction
p0470- Exhaust Back Pressure Sensor Circuit Malfunction
Old Mar 11, 2006 | 08:16 PM
Kwikkordead's Avatar
Kwikkordead
I googled P0602 and came up with this:
P0602 Control Module Programming Error
I don't know if it's a real problem or if it's simply as harmless as a P0603 which means you disconnected your battery at some point in time. I recommend you clear them out and go drive it for a while.
Here: http://www.svtlightnings.com/scantool/ford%20dtc%20codes.htm
