1978 - 1996 Big Bronco
Help with Vehicle Certification Label
Old Mar 11, 2006 | 04:45 PM
badlaw187's Avatar
badlaw187
I have an 89 Bronco and need help decoding the label.
Front Axle code = "19"
Suspension ID Code = " V Z"
Transmission Code = "T"
Paint Code = "9M"
District/Special Order Codes = "24"
Heres the VIN "1FMEU15N1KLA14572" but i have decoded that.
Anything is a help.
Here is a good VIN decoder I found.
http://shopkeysupport.com/sk5com/VIN/VIN.pdf
Old Mar 12, 2006 | 12:08 AM
justshootme84's Avatar
justshootme84
The axle code "19" is for the rear axle. Ford 8.8", 3.55:1 ratio, open carrier. The front axle is a Dana 44 TTB (Twin Traction Beam), gear ratio 3.54:1, open
Transmission code "T" is for the AOD, auto with overdrive.
Check the tech articles here at FTE, there is some info on the sticker codes.
Old Mar 12, 2006 | 09:43 AM
Streetgang's Avatar
Streetgang
Ok......I will pitch in also.
The paint code 9M is just plain jane white.
I hope that helps a bit.
