Identifying Pumpkins
Old Feb 1, 2001 | 07:30 PM
mhyff250's Avatar
mhyff250
Hello everyone~
How can you distinguish between a rear Dana 44, Dana 60, and the Dana 70? What about a front Dana 44 and Dana 60?
~Ryan
Old Feb 1, 2001 | 08:35 PM
Art's Avatar
Art
[font size="3" color="#191979"]
Size of the center casting after you've worked on several of them. However, Dana/Spicer cast a number right into a web of the casting on the outside that can be read if the axle is somewhat clean.
Dana 44's are usually used as rear axles in 1/2 tons and as front axles in 1/2 & 3/4 ton 4x4's.
Dana 60's are usually used as rear axles in 3/4 tons and as front axles in 1 ton 4x4's.
Dana 70's are usually used as rear axles in 1 ton trucks.
As with all rules, there are a few exceptions...
If the axle is still in a truck, the axle code on the VIN tag will tell you what axle the truck was built with.
Art
Old Feb 2, 2001 | 09:20 PM
gadams's Avatar
gadams
my axle code is 08, which I looked up as meaning I have a 3.5 rear end (if nobody changed it over the years). Is a Dana 44 a 3.5 rear end? Or are Dana 44's available in different ratios?
Greg
67 F100 Camper Special 390V8, med. case cruise-o
Old Feb 2, 2001 | 10:27 PM
Art's Avatar
Art
[font size="1" color="#FF0000"]LAST EDITED ON 02-Feb-01 AT 11:28 PM (EST)[/font][p][font size="3" color="#191979"]
No, actually it means 3.50 ratio Ford 9" without trac-loc. Should be 28 spline axleshafts. For 67-79 1/2 ton trucks, the 9" is far more common than the Dana 44.
The previous post was an answer to which Dana axles were used in which trucks. Dana 44, 60, and 70 axles all have a cover on the back.
Art
Old Feb 3, 2001 | 06:30 AM
gadams's Avatar
gadams
ahh. thank you very much. very informative.
Greg
green 67 F100 CS 390V8 cruise-o
Old Feb 3, 2001 | 08:09 AM
glenn 79's Avatar
glenn 79
Ryan hunter
Apr 12, 2015 02:30 AM
Ryan50hrl
Offroad & 4x4
15
Oct 11, 2004 10:16 PM
Ryan50hrl
Jun 5, 2003 09:53 PM
Ryan50hrl
May 29, 2002 08:48 PM
