Alternator mounting problems
Old Mar 11, 2006 | 11:19 AM
FordTruckGuySTX's Avatar
FordTruckGuySTX
How many of you are running a one wire alternator? I ordered one of the smallcase powermaster 100amps for my '77 ford and i tried a standard GM one wire previously and had a big head clearance issue. Well. I figured I might be safe now ordering the ford small case version, the small case alternator honestly though was a very tight fit. Well turns out that the back of it has a round protrusion, maybe part of the regulator or something and it doesnt clear the head. So right now with a lack of other brackets or ways to line it up on the pulleys I figured I would just notch the head out for it. Anyone saw any cheap alternate methods?
Old Mar 11, 2006 | 09:00 PM
Putt's Avatar
Putt
The small case Ford alternator clears the FE head by about 1/8" at the center rear. There is a bearing pocket that is closest to the head.
I would hesitate to grind on the head, there are passages close to the surface. That would make for a very bad day!
Old Mar 11, 2006 | 09:06 PM
Hypoid's Avatar
Hypoid
Have you tried re-clocking the alternator?
Old Mar 12, 2006 | 06:33 AM
FordTruckGuySTX
what do you mean reclocking? flipping it around?
Old Mar 12, 2006 | 11:55 PM
Putt's Avatar
Putt
Clocking is rotating the terminals to a different position in relation to the adjustment boss. Put the adjustment boss at 12 o'clock, if the terminals are up like the boss, it is 12 o'clock. To the right, 3 o'clock, etc.
atlanta1020
May 5, 2015 07:29 PM
1andonlywhitie
Mar 3, 2012 09:29 AM
Ashton_1012
Feb 22, 2012 10:09 PM
Red Ford Truck
Ontario Chapter
Mar 10, 2009 05:46 PM
Thor69x
Dec 24, 2008 11:09 PM
