Pre Fuel pump clamps?
Old Mar 11, 2006 | 09:54 AM
Rich in CO's Avatar
Rich in CO
I have been thing about doing the pre pump mod, and while reading through the threads I need to replace the qiuck clamps. While looking at my lines & pump all I se fo clamps are the typical hose clamps the one you can tighten witha flathead or small driver. are these the qiuck clamps every one is talking about?
Or has my clamps been changed already
Thanks
Rich
Old Mar 11, 2006 | 10:39 AM
Kwikkordead's Avatar
Kwikkordead
Thanks
Rich
Somebody must have done it already on your truck. The factory design is the quick connect style that requires that collar tool to release.
Old Mar 11, 2006 | 11:28 AM
Rich in CO's Avatar
Rich in CO
Thanks Kwik, When my tanks is full I don't have any cackle, but when I run the tank down the cakle comes back, so I'm assuming I need to do the in tank mod. and if that does not work I need to look at the #8 injector?
Old Mar 11, 2006 | 04:10 PM
Kwikkordead
If you want to. I have some crummy sounding injectors right now as well, but the truck runs ok, just noisy. And the typical tap tap tap tap from #8. But not bad enough to justify the big bux to buy a set. I'll probably have to soon enough.
