rear ratio
Old Mar 11, 2006 | 09:46 AM
mikeiz's Avatar
mikeiz
rear ratio
rear looks orig. po said it has a 4.10 really screams at 50mph.use 50% around town 50% on hiway what is a good ratio to replace it with,how hard, best place to buy parts thanks mike
Old Mar 11, 2006 | 05:32 PM
GreatNorthWoods's Avatar
GreatNorthWoods
What engine and transmission do you have? The engine and transmission will have a bearing on ratio you need ...
Vern
Old Mar 11, 2006 | 06:28 PM
AXracer's Avatar
AXracer
Welcome Mikeiz!
It is a lot easier to answer your questions if you give us info as to what vehicle year and model you have and what if anything has been changed from stock in your posts. AFA rear ratio the diameter wheels and tires you'll be using will also affect the choice of rear ratio. That all said ratio around 3.3- 3.7 behind a non overdrive tranny will probably be more to your liking. Unless you are doing a pure restoration it's likely to be better and cheaper to change the rear axle to something later with the proper ratio already in it than to try to find a new set of gears for yours and get them installed correctly. Check out under the articles and specs tab at the top of the page the article on rear axle choices for what axles you might use. Also do use the search function when you have a question as many of the common questions have been discussed in very deep detail previously and you may get a better answer there. If you can't find what you want to know, then ask away and you'll probably get more info than you really want!
