Bronco II Ford Bronco II
Starting & Block Heater
Old Mar 11, 2006 | 08:21 AM
zfrankowski's Avatar
zfrankowski
Hi Fellow Ford Fans!
Question for you all - I have a 1988 Ford Bronco II - everything works great except in the spring/winter/fall unless the block heater is plugged in the Bronco won't start. Has anyone else run into this? It's temperature related I'm guessing because in summer it starts fine. When it gets between below +10 celcius it needs to be plugged in. When it hasn't be plugged in it won't usually start for about 4-5 hours. It's frustrating! Any ideas?
Thanks - Zack
Old Mar 11, 2006 | 12:21 PM
OSin86's Avatar
OSin86
Hi Zack! Welcome to the club. Sounds like a simple battery or even a starter problem. I have a half dead 2.9 and it still started with easy, parked outside when it was -20 celcuis for a couple days this winter.
I would start with the battery. Take it out and have it tested at Autozone or Advance Auto for free. If you take it out they have a great bench test that will tell you for sure the condition of the battery. Sometimes if the charge is low you will have to leave it for up to 45min. If that checks out good then pull the starter and get that bench tested. It might be worn and not turning like it should.
Good Luck
Old Mar 11, 2006 | 12:48 PM
rebocardo's Avatar
rebocardo
You should not have a starting problem in the cold, especially with the 2.9. I have had the most ratted out 2.8L and various 2.9L and they started even when it was 0 F outside.
I agree, probably a bad battery, maybe bad cables. People never check the cables, but, if they are bad enough they can drop many volts and amps and make starting difficult in cold weather.
Old Mar 14, 2006 | 11:36 AM
kernel-panic's Avatar
kernel-panic
Possibly bad battery / starter... but has anyone thought that maybe the coolant isn't the right mix and the engine is freezing up? Just a thought... no offense
Old Mar 14, 2006 | 05:53 PM
my72ford's Avatar
my72ford
i agree it would have to be a weak battery or loose or corroded cable connections,i had to replace my cables a while back due to engine starting slow.hope this helps!
Old Mar 15, 2006 | 06:35 AM
OSin86's Avatar
OSin86
He said +10 celcius, that's like 50 degrees fehrenheit. I doubt it's freezing.........
