CPS question
Old Mar 10, 2006 | 11:08 PM
redneckboy's Avatar
redneckboy
CPS question
I see CPS on here a lot what is it? what does it control?
and where is it located?
Old Mar 11, 2006 | 01:18 AM
jtharvey's Avatar
jtharvey
Have you tried running a search on the forum? You should find a ton of information.
But, in short, CPS = Camshaft Position Sensor. It tells the computer at what point in rotation the engine is so the injectors can be fired at the correct time. It's located on the front of the motor, at about an 11:00 if looking at the crank pulley from the front of the motor.
Old Mar 11, 2006 | 03:21 AM
PTPDK9's Avatar
PTPDK9
I Thought I Saw It At 7 Looking From The Bottom Of The Truck.... Help Me Find It I May Not Have Found The Right Part...thanks
Old Mar 11, 2006 | 04:52 AM
Talltruck's Avatar
Talltruck
Just above the crank pulley on the passenger side.
Old Mar 11, 2006 | 06:56 AM
cnd999's Avatar
cnd999
http://www.dfuser.com/Install%20Guides/CPS.pdf
Hey Redneckboy try this link, it shows right where it is from under
Old Mar 11, 2006 | 01:01 PM
redneckboy's Avatar
redneckboy
Thank you for the help guys. How much does one run and can you get them like auto zone instead of ford.?
Old Mar 11, 2006 | 01:54 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Steer clear of AutoZone.
A good place to get them is the International Truck dealer ($99 or so). The Ford dealer part will cost you $175 or so.
Cody
Old Mar 12, 2006 | 12:49 PM
Dstosh's Avatar
Dstosh
Check Ebay, there is a guy on there that sells them and he has really fast shipping. I ordered mine on sunday and It came on wednesday, only because monday was a holiday.
Old Mar 12, 2006 | 07:50 PM
Talltruck's Avatar
Talltruck
I had to replace my water pump today; while it was apart I snapped this photo of the CPS:
[URL=https://www.ford-trucks.com/user_gallery/displayalbum.php?&userid=44667&albumid=21093]
