replacement panels
Old Mar 10, 2006 | 10:25 PM
78fordranger's Avatar
78fordranger
replacement panels
I am thinking about buying floor pans for my cab when I switch it to my other frame and was wondering how hard it was? I dont have a light weight welder I have a heavy welder which even when it it turned down I tried to weld some new peaces in my bed and burned right though them in a heart beat. So I was wondering if there is any other way to do it. and do I have to cut out the old ones?
Old Mar 10, 2006 | 11:24 PM
yeha4x4's Avatar
yeha4x4
you could check into a stitch welder. It attaches to a stick welder which I assume is what you have. It reduces the amperage and allows you to weld sheetmetal. J.C whitney has them and I think they are fairly cheap. I used my gas welding setup and yes you do have cut the old stuff out but it's not that bad.
Old Mar 10, 2006 | 11:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Try asking down here in the Guru forum.
Old Mar 10, 2006 | 11:44 PM
78fordranger
yeah I got a stick welder it is a heavy duty which we use to weld 1/2 inch and bigger steal I will check into what said about the stitch welder thanks for the help
Old Mar 15, 2006 | 07:36 AM
FortyFords's Avatar
FortyFords
Save your money and pick up a 110 v mig
Rich
