need to now spark plug placement
Old Mar 10, 2006 | 08:13 PM
77f-150bigblock400's Avatar
77f-150bigblock400
i got a 77 f-150 i need to know ontop of distributor witch one is one on the disrtibutor and then on
Old Mar 10, 2006 | 08:30 PM
53fatfndr's Avatar
53fatfndr
What?
If I can decode what you are asking.....Number one on the distributor cap should be marked with a number 1. The number one cylinder is the front cylinder on the left side of the engine. As you are facing the engine, it is on the passenger side, closest to the radiator. I'm assuming that this is for a 400 as well?
Old Mar 10, 2006 | 08:32 PM
Mil1ion's Avatar
Mil1ion
You are actually asking about firing order on a 400 and wondering where is the number one position on the distributor to get started....correct ?
In most cases number one position is positioned in the 1 o'clock position of a clock if you are looking at the cap from in front of the truck.
IIRC,
The rotor inside the cap turns counter-clockwise.
EDIT:
The Figure 1 isn't always cast into the cap.
Old Mar 10, 2006 | 08:33 PM
76 F-150 390FE's Avatar
76 F-150 390FE
1-3-7-2-6-5-4-8
dizzy spins CCW
#1 is the one twords the front of the rear clip on the cap.
front 1-2-3-4
of
engine 5-6-7-8
Old Mar 10, 2006 | 08:34 PM
ford390gashog's Avatar
ford390gashog
number 1 is marked on the cap. but most people when they restab the dizzy don't use that spot. so you must verify it.
Old Mar 10, 2006 | 08:37 PM
76 F-150 390FE
in the haynes book it has number one at about 1-2 o'clock and i checked my truck and that is where it is, but one thing i dont like about the haynes book is it only has 6 spots on the top of the cap in the picture.
Old Mar 10, 2006 | 08:39 PM
Mil1ion's Avatar
Mil1ion
You must be looking at the 6 cyl illustration ?
The one below that has 8.
Old Mar 10, 2006 | 08:42 PM
76 F-150 390FE
nope, big bold print at the top of the page, Chapter 2 Part B V8 engines, has a drawing of a v8, numbers out the pistons and gives firing orders for the v8s under it.
Old Mar 10, 2006 | 08:44 PM
Mil1ion's Avatar
Mil1ion
I went back to review the posts and noticed I had made a typo.
The 10 o'clock was meant to be a 1 o' clock.
Old Mar 10, 2006 | 08:46 PM
Mil1ion's Avatar
Mil1ion
Part B should be 6 cyl
and Part C should be V8's
What page are you looking at ?
Old Mar 10, 2006 | 08:49 PM
76 F-150 390FE
2b-1
2a is 6 cylinder
2c is general engine overhaul procedures
and my book number is 36054
Old Mar 10, 2006 | 08:51 PM
Mil1ion's Avatar
Mil1ion
All the haynes manuals I have are number 788
Old Mar 11, 2006 | 07:41 AM
77f-150bigblock400
ya i get all that but after 1 do u go to the left our right on distributor and is it left 1234 our right 12 ya get me
Old Mar 11, 2006 | 07:43 AM
ford390gashog
no you go in the order of the firing order. Seems like you are in over your head on this project maybe get someone to help you with it.
Old Mar 11, 2006 | 08:32 PM
trinogt's Avatar
trinogt
You can make any terminal number one... The ideal location is one which puts the rotor pointing at number one at TDC of compression stroke, where you have as much range of motion as possible to adjust timing without the advance dashpot hitting something before the proper timing advance is achieved.
Mark
