Heater-no flow
Old Feb 3, 2001 | 12:22 PM
BarryRenfro's Avatar
BarryRenfro
Heater-no flow
Can't seem to get any flow from water pump, doesn't matter where the hoses are hooked up.
does'nt heat up stays at 195* all time.
don't know whether its a bad pump or not.
I6 300 w/hedders 4bbl,rvcam 3 on treesoon to have o'drive.
Old Feb 3, 2001 | 12:59 PM
BADSF350's Avatar
BADSF350
Heater-no flow
if the truck doesnt overheat then its probably your heater core
Old Feb 3, 2001 | 02:51 PM
oz9609's Avatar
oz9609
Heater-no flow
Check to see if you have a water control valve in the heater hose. If so, could be stuck closed.
Old Feb 4, 2001 | 07:42 PM
classyfish's Avatar
classyfish
Heater-no flow
Old Feb 5, 2001 | 09:57 AM
BarryRenfro
Heater-no flow
new heater control valve, new core. am going to try a new water pump. everyone around here is stumped.
Old Feb 5, 2001 | 10:34 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Heater-no flow
Barry, make sure you have vacuum to the heater control valve. And check to see if the valve really does move when you move the control. (Mine tends to stick after not using it for a season). Don
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
Old Feb 5, 2001 | 10:38 PM
BarryRenfro
Heater-no flow
FIRST OF ALL I want to thank all of you for the quick responses to my delima. Guess what you don't get any flow if there are'nt any vanes on the little rotor inside of the pump. my first reaction after I pulled the pump off was oh how dumb!!!!! anyway thanks a whole bunch for your time and helpfull ideas.
Barry
