Couple Questions
Old Feb 4, 2001 | 09:32 AM
77_F150_4x4's Avatar
77_F150_4x4
Couple Questions
I want to turn my truck in to a street truck but keep it with the 2 1/2" lift and 32s what could i do to get it handle better? sway bars for the front and rear? would that help? I want to tear it down this summer and start restoring it with alot of powder coating and polishing of parts. For the 400 its going to be bored .030 over with 10to1 pistons in it alot of porting weiand intake comp cams 268H series cam, Would i need anything to make the bottem end stronger? I have seen main stud gurtles for the 351W what about for the M-block?
Thanks
Curtis
77_F150_4x4 aka
"The BeAsT"
Old Feb 4, 2001 | 10:44 PM
hillbillyk's Avatar
hillbillyk
Couple Questions
sway bars and heavy duty shocks will help alot for the handling, but is is a big truck and will only do so much, people hate it when they are in their little lowriders and you pass them in a big ol ford. heavy duty springs could be an option.
Old Feb 5, 2001 | 12:01 AM
fozzy's Avatar
fozzy
Couple Questions
I dont know about 4 wd , but I would like to know where you are going to get 10:1 pistons?? email me at seanwb@tisd.net
Old Feb 5, 2001 | 06:06 AM
77_F150_4x4
Couple Questions
For 10to1 or close to it i talked to a guy that builds these motors he said to have the rods bushed and run 351C flat tops.
Curtis
77_F150_4x4 aka
"The BeAsT"
Old Feb 5, 2001 | 08:08 PM
FE427TP's Avatar
FE427TP
Couple Questions
>2 1/2" lift and 32s
>what could i do to
>Thanks
>Curtis
>77_F150_4x4 aka
>"The BeAsT"
If you want to make it handle better get rid of the lift, and lower it a few inches, add sway bars, and get taller rims and low profile tires, Also, why have "alot of porting" to the heads, then run that small of a cam? I'd either leave the heads relatively stock and get a good three angle valve job a bowl cleanup and run that cam, or step up to a cam that will allow the porting to do some good, that cam is still a milage cam which doesn't really go with the higher lift flow increase "alot of porting" will give. Not to mention the M series heads already have ports that are fairly generous, flow improvement can actually gained by filling the bottom of the ports some. As in the exhaust plates they make for Cleveland heads for example. I dont know how high you want to spin the engine, but bearing speed should be a concern with the 3" mains. Step up to main studs if you want, but confer with your engine builder as he will probably know a lot more than me about that.
Old Feb 5, 2001 | 09:07 PM
85351ho's Avatar
85351ho
Couple Questions
can you even lower a 4x4.. you couldnt pay me to lower mine =), well maybe if the price was right, hehe
1985 F-150/351Ho/4wd/6inch with 33's
1979 f-250 429/4spd/6inch lift w/33's, soon to be 36's
on a quiet night your can hear the chevys rusting away
Old Feb 5, 2001 | 09:26 PM
77_F150_4x4
Couple Questions
That was the wrong cam i wrote down the right one is a Lunati Street Master Cam 2,000-6,000rpm .536/.562lift i am going to do it close to the hot rod mag. article did.I will need to keep it the same right for driving in the winter michigan roads suck and i just want to be able to do better then the new chevy and dodges that have a small lift on theres with duals and think they are the toughest thing out there. One more question will i need to put the chrome moly axle shafts in my dana 44 with it being the weak link to the drivetrain and putting close to 500tq to it?
Thanks
Curtis
77_F150_4x4 aka
"The BeAsT"
Old Feb 6, 2001 | 06:24 AM
77_F150_4x4
Couple Questions
One more question can i get a rollpan rear bumper for it? are they made for the 73-79 F-series?
Thanks
Curtis
77_F150_4x4 aka
"The BeAsT"
Old Feb 6, 2001 | 08:58 PM
dust3's Avatar
dust3
Couple Questions
Yes Lund makes a fiberglass rollpan for '73-'79 ford trucks, I have one on mine.https://www.ford-trucks.com/dcforum/User_files/3a80c78208c83715.jpg
Dustin
Old Feb 6, 2001 | 09:34 PM
77_F150_4x4
Couple Questions
[font size="1" color="#FF0000"]LAST EDITED ON 06-Feb-01 AT 10:49 PM (EST)[/font][p]Thanks well thats wrote down now too is there anyway i can get my truck to ride like the new 150s or better without going to the air bag suspension in front? i am planning on going with edelbrock performer ias shocks too any ideas ? Would i have to get the 4 shock pieces off a bronco? it has a 2 1/2" lift the coils are rough country are there any better coils for ride? If im running a 32s on it what size gears should i run with them?
Thanks
Curtis
77_F150_4x4 aka
"The BeAsT"
Old Feb 6, 2001 | 11:38 PM
400HP794x4's Avatar
400HP794x4
Couple Questions
