Propane question ?
Old Mar 10, 2006 | 01:39 PM
Saigon's Avatar
Saigon
Question Propane question ?
Does anyone know if butane has the same qualities as propane for an IDI ?
Thanks
Old Mar 13, 2006 | 11:29 AM
Hamberger's Avatar
Hamberger
Butane should work just the same. A little less energy density if I remember right than propane and butane is also a little bit more difficult to gasify so you may need a little more heat to keep the regulators from freezing up.
The only problem with butane is that it is a lot harder to get a hold off as it is not readily sold commercially like gasoline, diesel, or propane. The key would be to have access to a good cheap butane supply.
A lot of refineries use the butane they generate to manufacture high octane gasoline stock (100+) in a process called propriotory process called "Alkylation" so they typically will not sell butane as they get more bang for the buck by converting it to high octane gasoline.
I have though about Butane but given that I don't have access to a reliable, cheap supply that would be readyly available it will remain just that, a thought.
Old Mar 13, 2006 | 11:48 AM
Saigon's Avatar
Saigon
Talking
Here in France butane is readily available just about everywhere,there are 35 kilo bottles and down to 2 kilo bottles for camping. The 35 kilo bottles cost about $23.00 but they are pretty big, I was thinking of a smaller container just to give my engine a "kick" at the green light!
Old Mar 13, 2006 | 01:02 PM
Hamberger's Avatar
Hamberger
Butane
I have not seen any large (35 kilo) bottles of butane around here. Most campers use propane which is available at many corner gas stations. You can usually get a standard 20 lb BBQ tank filled for about $15 to $20 CDN.
Strictly for a fuel point of view propane and butane are not that different.
Just be careful, butane and propane are a lot more dangerous than Diesel Fuel when it comes to handling and storage. Good luck.
Old Mar 13, 2006 | 03:15 PM
Saigon's Avatar
Saigon
Thanks Hamberger.... bye the way, I still have those Bosch gp's made in Deutchland,they are great !
Saigon
Old Mar 13, 2006 | 04:53 PM
Hamberger's Avatar
Hamberger
Meine Bosch gluekerzen from Deutschland arbeiten sehr gut. Sie solten es leicht bis 100,000 km schaffen.
Sebastian.
