straight axle swap
Old Mar 10, 2006 | 01:43 AM
GPSMatt's Avatar
GPSMatt
straight axle swap
Ive got a 85 f350 deisle its got thte d44hd ttb setup i got a d60 for up front. For now i am just gunna run it on the stock leafs.. My question is what leafs will fit this are they the same as hte f250 leafs with this setup can i put leafs off of a litle bit newer f350 with straight axle up front?
Old Mar 10, 2006 | 06:16 PM
Dave Sponaugle's Avatar
Dave Sponaugle
It will bolt right up to the stock springs.
The 350 front springs will probably be the same springs you have now.
X code springs are a heavier spring rate, X code 250 and X code 350 springs are the same spring.
I had a local spring shop build me a set of 4 leaf X springs for mine. 600 dollars for both springs and all the mounting hardware last year. Now when I put my snow plow on, the truck don't even know it is there.
