Mechanical Vs. Electrical Fuel Pump?
Old Feb 6, 2001 | 04:45 PM
79supercab4x4's Avatar
79supercab4x4
Just a quick question, does running either an electrical or a mechanical fuel pump make any difference at all in fuel economy? that is assuming everything is kept the same and its driven the same. also, are there any differences in performance?
Old Feb 6, 2001 | 08:17 PM
FE427TP's Avatar
FE427TP
I run a electric pump but it's because it was in the truck when I bought it and my new mechanical fuel pump couldn't deliver enough fuel to the carb at high RPM, and the electric can.
Old Feb 6, 2001 | 08:23 PM
mattlm's Avatar
mattlm
If the fuel pump did effect the fuel economy then something is broken. A fuel pumps only job is to keep the float bowl full. It's the carb that sucks it out.
To quote my dad "delivering fuel to the carb has all the complexity of a toilet"
Matt Miller
Old Feb 6, 2001 | 10:54 PM
79supercab4x4
haha...thats a good quote that ill have to remember. thats how i thought it worked but im just making sure. by the way...has anyone out there had problems with electrical pumps going out constantly? ive gone through 4 of them in the past year and a half. maybe ive just coincidentaly had lemons...i always mount them as close to the tank as possible, below the level of the tank, and with a filter before it. anyway, i finally just got a mechanical one and had no problems so far. well thanks for the help.
Old Feb 6, 2001 | 11:33 PM
400HP794x4's Avatar
400HP794x4
I have a electric pump, the only way to go if you ask me. It was the only thing that would keep my carter AFB from vapor locking. I have a red holley electric pump. The first one lasted 3 years, not bad for an electric pump.
Old Feb 9, 2001 | 06:57 AM
jowilker's Avatar
jowilker
Old Feb 9, 2001 | 08:44 PM
Trail_Rider's Avatar
Trail_Rider
I had a stretch when I was having problems with electric pumps and it turned out to be a clogged pickup in the tank.
Trail Rider
Old Feb 10, 2001 | 05:02 PM
michael 3807's Avatar
michael 3807
you might think about removing that filter on the suction side of your fuel pump electric pumps are made to push fuel not pull it that is why they want you to put it close to the tank as possible what.
what is failing on your pumps valves or elect.
if it is valves suction is the problem.
if it is electric you might have a grounding problem or poower supply problem.
hope this helps keep us posted
Old Feb 10, 2001 | 08:10 PM
fozzy's Avatar
fozzy
I bought summits HP fuel pump kit/gauge and its the noisiest thing next to a whiny P/S pump....but it does a good job, so its stays
**HINT** if your electric fuel pump is too noisy , cut up as thick mouse pad into 4-6 even squares and make a sandwich out of them, then make two holes for the mounting bolts , and put the "sandwich" between the pump bracket and the frame... the rubber mouse pad isolates the resonating sound from the truck bed and frame
