4r100
Old Mar 9, 2006 | 01:57 PM
renchr56's Avatar
renchr56
Cool 4r100
I have a 99 f-350 . The trans went out & I installed another Ford Reman unit. The problem is that after install & putting the truck into reverse there is a very soft delay/shift. All other gears work fine. Checked all pressures & they are all right, but in reverse you have to get pressures up to 125psi. or 1300 rpm. Help please? Ford said that possibly the pcm needs to be reflashed. I can't understand why when other transmission worked fine until recently.
Old Mar 9, 2006 | 04:52 PM
twayneb's Avatar
twayneb
Had the same problem in my 2000. The dealer replaced the solenoids and every thing is now fine.
