e4od problems
Old Mar 9, 2006 | 12:41 PM
austin834's Avatar
austin834
e4od problems
I have a 93 ford f-150 E40d tranny. And im rebuilding it right now and i came to a point on where i just got stumped... Is there supposed to be somewhere in this transmission that 2 needle bearings are placed one on top of each other like you have one bearing then another one lays on top of it??? and also another question about the clutch drums.. when your replacing the seals... these seals have a space in them in the middle section all the way around them... how do they go in.. there the seals for the clutch piston.. i know the fluid pushes up on the seals to push the piston up but do i have to have it where a lip is sticking out so the fluid gets caught???
